Some time ago on our beloved chatroom I mentioned my idea for - in my humble opinion - a damn good series.
Since I currently have RWMT lining up, I won't start this series just yet, but I'll give you a hint of what it would be like.
Race calendarFour double-header races in the off-season is the plan.
This would be either solely road track racing or some ovals would be thrown in for good measure. All the races will be time limited to 45 minutes + 1 lap.
ChassisThe cars would be based on the Formula Armaroli chassis. All the teams have identical cars (digital RPM gauge, H-pattern gearbox) with no additional upgrades.
Liveries are mostly non-restricted, except for placement of numbers.
EnginesAll the chassis will be equipped with F1 engines that once powered the mighty rejectful cars of the 90s (1990-1999) - just to ensure the equality between the cars.
You can choose from engines of such manufacturers as: Hart, Judd, Motori Moderni, Cosworth etc.
Some engines are simply rebadged powerplants of other manufacturers. To make sure these engines will be more varied in performance, every team has to specify the car from which the engine was taken. For example: ex-Life Judd won't have the performance of, let's say, ex-EuroBrun Judd, and European V10 won't be anywhere close to Ford Zetec R, performance-wise.
After some consideration, unraced engines will also be available to pick. That gives you an additional choice of engines manufactured by: MGN, Isuzu, Lola, Neotech or HKS.
I might try and run it in the 2017-2018 off-season for your amusement, but you know how things are with me and running series.
Going by Keynesian terms - if there's a demand, there shall be a supply!
