takagi_for_the_win wrote:go_Rubens wrote:darkapprentice77 wrote:Donington Park.
It is better than Silverstone!
Jesus, this is beginning to look like the 'Bash every track used by F1 recently' thread
Albert Park is a bunch of tight 90-degree corners with no character; compare to Adelaide, a bunch of tight corners
with character.
Sepang has 5-6 and 7-8 which are kind of cool, the rest of the corners are just your typical tight and/or overcomplicated Tilkedrome things.
Shanghai is basically the same track as Sepang. Double hairpin, medium-short right-turning straight, tight right-hander, short straight, left-right sweeping turn combo, double-apex turn, short straight, complicated turn(s), long straight, hairpin... ugh.
Bahrain is boring tight corners with a double sweeping combo and decreasing-radius turn thrown in there, just like all the other Tilke tracks.
Catalunya doesn't have any good overtaking opportunities.
Monaco has nowhere to pass and it's way too unsafe to be in F1 today.
CGV is just a bunch of indistinguishable chicanes.
Silverstone actually has too many high-speed corners, such that it neglects overtaking.
The new Nürburgring is a bunch of overly tight corners and chicanes. It definitely doesn't have the variety or challenge of the Nordschleife.
The Hungaroring has nowhere to overtake, and doesn't even have anything else to make it interesting, like the unique, inspiring high-speed corners of Silverstone or the unforgiving challenge of Monaco.
The new Spa, when you think about it, is a bunch of 90-degree corners, a hairpin, and a couple chicanes.
Monza is a power circuit interrupted by the occasional slow chicane.
Singapore is just a bunch of angular 90-degree turns and chicanes.
Korea has two long, boring straights and a long, twisty section with a bunch of medium-speed corners that all feel the same where it's impossible to overtake.
Suzuka has been on the calendar for a long time without being significantly changed, automatically making it a good track.
India is a mass of tight corners with a token high-speed changing-radius turn, same as all the other Tilkedromes.
Abu Dhabi has the same problem as Singapore.
CotA is a bunch of hairpins with the good corners plagiarised from Istanbul and Silverstone.
Interlagos has been on the calendar for a long time without being significantly changed, automatically making it a good track.
