F1 Rejects Fantasy Game - Join now!
SuperAguri
Post by SuperAguri »
With the F1 season nearly here, so how about a complex but fun fantasy f1 game. There will be a prize for the person with the most points in the event of a tie there will be a tie breaker. There is also a wooden spoon prize for the person with the worst points total.
Choose wisely as you won't be able to change... :D
Choose a team and two drivers
No person may have the same team and driver set up and if this happens you will be asked to choose again.
You have $40m to spend on a team and 2 drivers. You can spend less then $40m (and get bonus points for doing so) but you may not spend more then $40m...
F1 Rejects Championship Game
General (Drivers only)
50 points for not doing the race weekend (no other points count)
Practice (Drivers only)
5 points for not doing a run
10 bonus points if they fail to do any runs (a run is a single timed lap) during any test session.
5 points for being the slowest runner in a session (regardless of reason)
-10 for 1st fast session time
-8 for 2nd
-6 for 3rd
-5 for 4th
-4 for 5th
-3 for 6th
-2 for 7th
-1 for 8th
Qualifying (Drivers)
1 point every 0.1 second off Q1 provisional pole time
8 points for not doing any runs in Q1
5 points for not doing any runs in Q2
3 points for not doing any runs in Q3
2 points for every 0.1 second off fastest practice time
-1 point for every 0.1 gained on fastest practice time
-9 for 2nd
-8 for 3rd
-7 for 4th
-6 for 5th
-5 for 6th
-4 for 7th
-3 for 8th
-2 for 9th
-1 for 10th
(if no time set then no points are lost)
1 point for every grid row you drop after qualifying
Qualifying (Team only)
5 points if one of your teams drivers fails to make it past Q1 but the other makes it to Q3
-10 points if both make it into Q3
10 points if both fail to get out of Q1
Brundles Gridwalk (All)
-5 points if Martin talks to one of your drivers
-5 points if Martin talks to a member of your team
5 points if Martin wants to talk to a driver and he isn't available (toilet, talking to other media)
5 points if Martin wants to talk to a member of your team and he isn't available
-3 points if Martin interupts another media person to interview your driver
-3 points if Martin interupts a team member talking to your driver
5 points if your driver tells Martin to go away
3 points if team member tells Martin that driver is busy
Bernie Bonus (or Unbonus...)!
Triple points if Martin talks to Bernie on the gridwalk
-10 points if your team or driver is mentioned by Martin or Bernie
After Lap 1 (Drivers only)
3 points for every place lost
-2 points for every place gained
5 points if you have to start in the pitlane
5 points for causing someone else to pit at the end of lap 1
10 points for stalling on the grid (but managing to get away, see also retirements)
10 points for having to pit at the end of lap 1
10 points for being last after lap 1 (excludes people starting in pitlane)
-10 points for leading after lap 1
Pits (Drivers only)
1 point for every 0.5 second above the average total pitstop time
-2 point for every 0.5 second under the average total pitstop time
5 points for having to pit for non tyre change
10 points for causing another driver to have to pit
10 points for a stop go penalty
15 points for hitting one of your pit crew
25 points for going to the wrong pitbox
Retirements (Drivers only)
1 point for mechanical failure
3 points for retiring in pits
3 points if another driver takes you out (tripled if team mate, doubled if your other driver or a driver of your choosen team)
5 points for driver error (doubled if car is very damaged (tire off, front or wear wing off, sidepods smashed))
5 points for taking a driver out (tripled if team mate, doubled if your other driver or a driver of your choosen team)
5 points for tyre failure
10 points for stalling and retiring
20 points for being black flagged
25 points for running out of fuel
3 bonus points for every other involved in a crash that causes a retirement
Race End (Drivers only)
2 point for every place you lost from grid position
-1 point for every place you gained from grid position
5 points for being last (crossing start and finish line)
5 points for retiring but still classified
10 points for retiring on the last lap
10 points for being disqualified after race (before post race celebration)
10 points for getting a time penalty after the race (race finish will not be calculated until well after the event)
20 points for finishing but not being classified
20 points for being disqualified after race weekend
2 bonus points for every lap your driver was lapped
-10 for 1st
-8 for 2nd
-6 for 3rd
-5 for 4th
-4 for 5th
-3 for 6th
-2 for 7th
-1 for 8th
Fines (Drivers only)
1 point for every $10,000 you are fined (if fined $50,000 you get 5 points) during the race weekend
Sackings (Drivers only)
25 points if one of your drivers is sacked
10 points if your driver is replaced by the test driver
-10 points if your driver is replaced by another driver
Sackings (Teams)
10 points if your team sacks a driver
Team points
5 points if one car retires
15 points if both car retires
5 points if both cars finish together outside the top 8
-5 points if both cars finish together inside the top 8
(no points if you happen to come 8th and 9th)
-10 for 1st
-8 for 2nd
-6 for 3rd
-5 for 4th
-4 for 5th
-3 for 6th
-2 for 7th
-1 for 8th
3 points for every place your team loses on average
-3 points for every place your team gains on average
(ie if they qualify 4th and 6th, then the average place is 5th, if they finish 3rd and 11th, then the average place is 7th and they would get 6 points (5-7 is -2 so lose 2 places, although they would lose 6 points for finishing 3rd...)
50 points if your team withdraws from the series (see below)
20 points if your team fails to attend a race
50 points if your team is kicked out of the series by the FIA
Reject of the Race (All)
15 points for being reject of the race (team or driver)
10 points if a team member of your team is reject of the race
5 points for having a driver who is team mate for reject of the race
5 points if a team (or team member) is reject of the race and one of your driver drives fo
r them
5 points if a driver is reject of the race and one of your teams has that driver
(if the RoR is awarded to a object or person outside of a team then no points will be awarded)
IIDOTR (All)
-15 for being IIDOTR
-10 points if a team member of your team is IIDOTR
-5 points for having a driver who is team mate for IIDOTR
-5 points if a driver is IIDOTR and your team has that driver
(if in a unlikely event IIDOTR is awarded to a object or person outside of a team then no points will be awarded)
Other
20 points for every $5m you are under budget.
If your driver is sacked or made reduntant then you will score no further points the rest of the season, same goes for teams who withdraw from the series.
If your driver is killed or injured then the replacement driver will take over the unfortunate driver role.
If your choosen team withdraws for the series then no more points will be scored even if they come back or are replaced.
Teams (Choose one)
$0m Mclaren
$0m Ferrari
$5m Mercedes
$5m Red Bull
$10m Williams
$10m Sauber
$15m Renault
$15m Force India
$20m Toro Rosso
$20m Lotus
$20m Virgin Racing
$25m HRT-F1
Drivers (Choose two)
$0m Jenson Button
$0m Lewis Hamilton
$0m Michael Schumacher
$5m Ferando Alonso
$5m Felipe Massa
$5m Sebastian Vettel
$10m Rubens Barrichello
$10m Kamui Kobayashi
$10m Robert Kubica
$10m Nico Rosberg
$10m Mark Webber
$15m Sebastien Buemi
$15m Pedro De la Rosa
$15m Nico Hulkenberg
$15m Vitantonio Liuzzi
$15m Adrian Sutil
$15m Jarno Trulli
$20m Jamie Alguersuari
$20m Timo Glock
$20m Heikki Kovalainen
$20m Vitaly Petrov
$20m Bruno Senna
$25m Karun Chandhok
$25m Lucas di Grassi
<@Ataxia> these people are making a mess of their crepe suzettes
SuperAguri
Re: F1 Rejects Fantasy Game - Join now!
Entries must be in before Friday practice of the Barhain Grand Prix!!!!!
Brundles gridwalk is BBC TVs F1 coverage that fetaures Martin Brundles doing a Gridwalk just before the race.
Any questions about points, please send to me. Although my decision is final and all sources used to calculate points will be given.
thehemogoblin
Post by thehemogoblin »
Jarno Trulli
Vitantonio Liuzzi
Williams
MinardiFan95
Post by MinardiFan95 »
Robert Kubica
Kamui Kobayashi
Williams
This is a cool spot.
TomWazzleshaw
Post by TomWazzleshaw »
So basically this is a fantany competition... in reverse... I like :twisted:
Robert Kubica
Kamui Kobayashi
Renault
Edit: What if your driver is talked to by Brundle and something like this or this happens and it involves one of your drivers? :lol:
Williams
Pedro de la Rosa
Vitantonio Liuzzi
SuperAguri
Wizzie wrote:So basically this is a fantany competition... in reverse... I like :twisted:
Yes, rejectful actions score points. Things like winning and being fast count against you.
If Martin doesn't talk to the driver (as with the first video with Schumacher) then the driver won't lose any poiints).
Tealy
Post by Tealy »
Williams
Senna
Kobayashi
Williams is a popular choice so far :P
I'm hoping Senna can lead me to glory because Kobayashi probably won't get me too many points.
madcat
Post by madcat »
Virgin
Karun Chandhok
Lucas di Grassi
I need a wooden spoon... Who's going to keep scores?!
As i looked at my naked body in the mirror, i thought to myself,
"I'm going to get thrown out of Ikea any minute.".
SuperAguri
madcat wrote:Virgin
Karun Chandhok
Lucas di Grassi
You need a calculator first... you are not Ferrari, you do not have an unlimited budget, you have $40m your choices are worth $70. Try again!!!
I'm going to keep scores! :)
shinji
Post by shinji »
Williams
De la Rosa
Liuzzi
Better than 'Tour in a suit case' Takagi.
RAK
Post by RAK »
Renault
Robert Kubica
Vitantonio Liuzzi
Predicament Predictions Champion, 2011, 2018, 2019
They weren't the world's most competent team,
In fact, to be believed, their results must be seen,
Lola,
M-Mastercard Lola,
L, O, L, A, Lola!
Warren Hughes
Post by Warren Hughes »
Rubens Barrichello
Jarno Trulli
Renault
Nico Rosberg wrote:Break me down mentally? Good luck with that one.
:roll:
SuperAguri
shinji wrote:Williams
De la Rosa
Liuzzi
Kostas22 has this as his team and driver choices, please choose again.
Code: Select all
thehemogoblin Williams   Trulli     Liuzzi
MinardiFan95  Williams   Kubica     Kobayashi
Wizzie        Renault    Kubica     Kobayashi
kostas22      Williams   De la Rosa Liuzzi
Tealy         Williams   Senna     Kobayashi
RAK           Renault    Kubica    Liuzzi
Shinji        DNQ
Madcat        DNPQ
These are the choices so far. So far everyone been very middle of the road, with Williams having 67% of teams choosen with Renault on 33%. Kubica, Kobayashi and Liuzzi are all popular making up 25% each of the drivers choosen with Senna, De la Rosa and Trulli making up 8% of the drivers choosen. Minardifan95 and Wizzie making smart choices and getting bonus points. So Minardifan95 is currently in the lead!
FloProAct
Post by FloProAct »
Virgin
Kobayashi
Kubica
shinji
Post by shinji »
Williams
Buemi
Webber
SuperAguri
As there is no rule to stop me from entering :D
Ferrari :o
Sebastien Buemi :|
Karun Chandhok :lol:
Niallllll
Post by Niallllll »
Lotus 20m
Jarno Trulli 15m
Felipe Massa 5m
Shadaza
Post by Shadaza »
The Force
Chandhook
Schumacher (Gamble I know)
Not trying to be a downer but It took me 10 minutes to read all the rules, how are you gonna log the results for every team and driver for every practice, qualy, race and post race? rather you then me anyway.
Message me on Discord.
Bleu
Post by Bleu »
Schumacher
Kovalainen
Toro Rosso
P_Friesacher
Post by P_Friesacher »
Must be a load of work, so thanks for setting up this game!
Williams.......10
Liuzzi..........15
Trulli..........15
TOTAL........40
SuperAguri
Shadaza wrote:Not trying to be a downer but It took me 10 minutes to read all the rules, how are you gonna log the results for every team and driver for every practice, qualy, race and post race? rather you then me anyway.
Some of it is easy, some of it is more complex. But a mixture of scripts (to get times and names off websites), a BASIC (woo hoo high tech...) program (to work out points for practice, qualifying and race times) and a spreadsheet (adds all the points) will do most of it reasonably quickly. I still have to watch the race and note down things and enter that into the spreadsheet. I did a test using last years Monaco GP and it took me just under an hour to do. :)
Like the F1 Rejects podcast there may be some time after the race finishes before i post results though.
SuperAguri
P_Friesacher wrote:Must be a load of work, so thanks for setting up this game!
Williams.......10
Liuzzi..........15
Trulli..........15
TOTAL........40
Yep 40 million on the dot but thehemogoblin has already pick that combination. So try again or you will get a DNQ!
P_Friesacher
Williams
Webber
Kovalainen
does not seem to be taken yet.
tristan1117
Post by tristan1117 »
Sauber
Kubica
Senna
CoopsII wrote:On occasion I have ventured into the PMM forum but beat a hasty retreat soon after as it resembles some sort of bad acid trip in there
Phoenix
Post by Phoenix »
Team: Force India.
Drivers: Vitantonio Liuzzi, Rubens Barrichello.
HRT, Michael Schumacher, Kamui Kobayashi
Debaser
Post by Debaser »
Virgin
Jenson Button
Jarno Trulli
eytl
F1 Rejects Founder
Post by eytl »
There's no rule that says I can't enter ... and I promise that we won't be making ROTR decisions to favour my team!
Mercedes
Timo Glock
Jarno Trulli
thehemogoblin
Williams.......10
Liuzzi..........15
Trulli..........15
TOTAL........40
I'm glad I got here quick.
Pedestrian
Post by Pedestrian »
First of all: Greetings to the founders and to the community as a whole
I'm a long time reader of the site and lurker on the forum until now, but this sounds like fun, so I'll jump in:
Torro Rosso
V Petrov
M Schumacher
Bad luck everyone and may the worst team win :lol:
thalion
Post by thalion »
Renault
Robert Kubica
Jarno Trulli
All popular choices, but I think I'm the first to have them all.
SuperAguri
Here is what has been choosen so far. The number at the end is the current points, no number = no points.
Code: Select all
MinardiFan95   Williams    Kubica       Kobayashi  40
Wizzie         Renault     Kubica       Kobayashi  20
FloProAct      Virgin      Kubica       Kobayashi
Warren Hughes  Renault     Barrichello  Trulli
Shinji         Williams    Buemi        Webber     20
SuperAguri     Ferrari     Buemi        Chandhok
Niallllll      Lotus       Massa        Trulli
Shadaza        Force India Schumacher   Chandhok
Bleu           Toro Rosso  Schumacher   Kovalainen
P_Friesacher   Williams    Kovalainen   Webber
tristan1117    Sauber      Kubica       Senna
Phoenix        Force India Barrichello  Liuzzi
Dr-baker       HRT         Schumacher   Kobayashi  20
Debaser        Virgin      Button       Trulli     20
Eytl           Mercedes    Glock        Trulli
Pedestrian     Toro Rosso  Schumacher   Petrov
It's intresting to see the drivers that have been choosen the most... I hope people are choosig Kobayashi due to them liking him rather then people thinking he will be Mr Crash. Poor Kubica too.... And I assume people are thinking Trulli trainwreck... Still people are thinking are thinking that Schumacher will be the new Nigel Mansell (Mclaren) or Villenueve (BMW). At the bottom of the list, people are giving the usual suspects of Hamilton, Alonso, Vettel a wide berth but I am surprised at no one choosing Rosberg,Sutil and especially Alguersuari (!!!!) or the rookies Hulkenberg or di Grassi...
13% (5)
Kobayashi
Kubica
Trulli
10% (4)
Liuzzi
Schumacher
5% (2)
Barrichello
Buemi
Chandhok
Kovalainen
Senna
Webber
3% (1)
Button
De la Rosa
Glock
Massa
Petrov
0% (Unloved)
Hamilton
Alonso
Vettel
Rosberg
Hulkenberg
Sutil
Alguersuari
di Grassi
People still think Williams will be a reject worthy team this year..
30% (6)
Williams
15% (3)
Renault
10% (2)
Force India
Toro Rosso
Virgin
5% (1)
Ferrari
HRT
Lotus
Mercedes
Sauber
Toro Rosso
0% (Unloved)
Mclaren
Red Bull
This is just teams with the most choosen drivers... :D Nice to see the top and the bottom teams....
Teams by drivers choosen
Lotus 18% (Trulli and Kovalainen)
Renault 15% (Kubica and Petrov)
Sauber 15% (Kobayashi and De la Rosa)
Force India 10% (Liuzzi)
Mercedes 10% (Schumacher)
Toro Rosso 10% (Buemi)
HRT 5% (Chandhok)
Red Bull 5% (Webber)
Williams 5% (Barrichello)
Ferrari 3% (Massa)
Mclaren 3% (Button)
Virgin 3% (Glock)
homerbhoy
Post by homerbhoy »
Virgin
B Senna
M Schumacher
Pieman
Post by Pieman »
Robert Kubica
Pedro de la Rosa
Sauber
Forza Forti
RAK
Post by RAK »
SuperAguri wrote:At the bottom of the list, people are giving the usual suspects of Hamilton, Alonso, Vettel a wide berth but I am surprised at no one choosing Rosberg,Sutil and especially Alguersuari (!!!!) or the rookies Hulkenberg or di Grassi...
di Grassi's too expensive, and for that price, you can have Chandhok, who I think is a better choice for an F1 Rejects game, with his mediocre GP2 Series season finishes. I'll agree with you about Alguersuari and Hulkenberg, though, as they could make good choices this year, but Rosberg has a better team to support him, and Sutil has shown flashes of brilliance before.
Lola,
M-Mastercard Lola,
L, O, L, A, Lola!
Pedestrian
It's intresting to see the drivers that have been choosen the most... I hope people are choosig Kobayashi due to them liking him rather then people thinking he will be Mr Crash. Poor Kubica too.... And I assume people are thinking Trulli trainwreck... Still people are thinking that Schumacher will be the new Nigel Mansell (Mclaren) or Villenueve (BMW). At the bottom of the list, people are giving the usual suspects of Hamilton, Alonso, Vettel a wide berth but I am surprised at no one choosing Rosberg,Sutil and especially Alguersuari (!!!!) or the rookies Hulkenberg or di Grassi...
I suppose most of us aren't really playng to win. This being F1 rejects, it would not feel right to spend the race hoping for the obvious underdog to fail.
Else, we would all be chosing Team Hispania.
Pedestrian
And sorry for spaming, but may I respectfully make some respectful sugestions regarding the scoring.
1)I think drivers should also earn some points for being beaten by their teammates.
2) In the cas of retirements, there should be a large bonus for retiring from the lead (doubled if boh chosen drivers retire while leading, quadrupled if both drivers of chosen team retire while leading)
Just my humble sugestion.
SuperAguri
Hmm, thank you for the good suggestions. However as I've already done the driver list, it would be unfair to add extra points now as it would affect the people that have already choosen their drivers. However I have made notes and will introduce something next year if this game goes well :D Be fun to see what works and what doesn't. Probably tweak points and gaps to make it more closer.
thalion
Post by thalion »
Also bear in mind that we all make our decisions based on the budget available. I'm sure that HRT is most likely to score points, but they're also the most expensive. That, coupled with the fact that teams don't have nearly the point-scoring potential of drivers based on your system, means that going for a better team and getting more rejectful drivers seems optimal at this point in time.
